Close
Click here to remove Ads Click to put your ad here
* * * * * 1 votes
Medieval Style Slingshot Crossbow?
  • Please log in to reply
42 replies to this topic
#1 JoergS
JoergS
    2000 Post Club
  • Registered
  • 2,100 posts
  • LocationLichtenfels County, Upper Franconia, Germany
Posted 11 June 2011 - 11:09 AM
What would you guys think about a medieval-style crossbow (for shooting balls of course), operated with pretensed rubber instead of the hardened steel spring?
Something like this:
http://js-armbrust.c...is_Communis.gif
#2 harpersgrace
harpersgrace
    2000 Post Club
  • Registered
  • 2,755 posts
  • LocationNorth East USA
Posted 11 June 2011 - 11:50 AM
Interesting idea. Will be looking forward to seeing what you come up with,
#3 shawnr5
shawnr5
    500 Post Club
  • Registered
  • 527 posts
  • LocationSan Tan Valley , Az
How about a curved bow on the front with the bands attached to the ends and going forward, around bearings, then back to the projectile. It would be like a compound slingshot.
#4 Nico
Nico
  • Banned
  • 729 posts
  • LocationResigned
Posted 11 June 2011 - 02:18 PM
I'd like to see that, I am very fascinated with and in search of working medieval style stone crossbows and this would be a cool alternative..
Nico
#5 NightKnight
NightKnight
    SSF Founder
  • Administrators Admin
  • 4,553 posts
  • LocationCentral Florida, USA
Posted 11 June 2011 - 03:14 PM
Would love to see it!
#6 Aras
Aras
    500 Post Club
  • Registered
  • 661 posts
  • LocationLithuania
Posted 11 June 2011 - 03:33 PM
actually, I have made a crossbow like this out of lego's with rubber bands
#7 Simon Van den Broeck
    100 Post Club
  • Registered
  • 104 posts
  • LocationBelgium
Posted 11 June 2011 - 04:29 PM
Or maybe with arms that swing away from it , to give it more speed .
Simon
#8 shawnr5
shawnr5
    500 Post Club
  • Registered
  • 527 posts
Posted 11 June 2011 - 04:37 PM
Simon, if you are thinking along the lines of a ballista, I don't think that you'd get enough stretch out of the bands . You would have to have awkwardly long extensions to get the tension necessary on the bands.
Edited by shawnr5, 11 June 2011 - 05:06 PM.
#9 Guest_SlingshotSean_*
  • Guests
Posted 11 June 2011 - 06:12 PM
Shawn you should build one. Looks like you have a knack for cad and good ideas.
#10 shawnr5
shawnr5
    500 Post Club
  • Registered
  • 527 posts
Posted 11 June 2011 - 06:16 PM
Thanks, Sean. My cave drawings are the result of MS Paint, not any sort of CAD. I have to finish the arrow-shooting slingbow I started several months ago before I even think of building something like this.
#11 Charles
Charles
    4000+ Post Club
  • Moderators Moderators
  • 4,709 posts
  • LocationBritish Columbia
Posted 11 June 2011 - 08:26 PM
How would this differ from other crossbow slingshots you have built?
Cheers ...... Charles
#12 JoergS
JoergS
    2000 Post Club
  • Registered
  • 2,100 posts
Posted 11 June 2011 - 09:38 PM
Shorter.
Wider fork (looks like a crossbow "prod").
Rubber is pre-stretched.
Release is a rotating "nut" like in a crossbow.
Long trigger (the "tickler").
Has a stirrup.
Looks like a medieval crossbow.
Enough differences?
Edited by JoergS, 11 June 2011 - 09:41 PM.
#13 Daniel J
Daniel J
    250 Post Club
  • Registered
  • 344 posts
  • Locationbrisbane QLD Australia
Posted 12 June 2011 - 05:33 AM
i like the idea of u making a medieval crossbow, but it would be a lot more interesting if used the other idea for the forks in your video about the ballista thing on youtube. because it would be the first time i see one.
#14 NoSugarRob
NoSugarRob
  • Banned
  • 2,855 posts
  • LocationEngland UK
Posted 12 June 2011 - 06:25 AM
yep, i'd like to see it.
#15 Lizard_King
Lizard_King
  • Registered
  • 20 posts
  • LocationTuzla , Yugoslavia
Posted 12 June 2011 - 07:29 PM
I have allready made it ,,it was funcional but need more work ,,
I used prestreched rubber ,, And you can shot arrows and balls with it ,,
sorry I dont have orginal pictures ,, here is a mspaint scetch I made now ,,
Its very powerfull..
Posted Imagehttp://i264.photobucket.com/albums/ii189/metallmind/crosbow.jpg
Here is another Fast drawing pitcure :D ,,
it should look something like that ,,..
Posted Imagehttp://i264.photobucket.com/albums/ii189/metallmind/samostrel1.jpg
sorry I dont have orginal pitcures of my homemade crossbow with rubber bands ,
hope I could help
Edited by Black7, 12 June 2011 - 07:46 PM.
#16 Charles
Charles
    4000+ Post Club
  • 4,709 posts
Posted 12 June 2011 - 08:08 PM
It will be interesting to see how it works out. The draw length is very short for a slingshot. The extra elongation of the bands from their front position to their rear position will be very little if the original "bow" arms have significant length. I do not think elastic bands are as "fast" as a bow, so my guess is that it will not have significant power unless the dimensions are changed significantly. But you never know until you try it!
Cheers ..... Charles
#17 Lizard_King
Lizard_King
  • Registered
  • 20 posts
Posted 12 June 2011 - 08:17 PM
That is a fast drawing , dont mind dimensions ,,and bad writeing . :D
The rubber band is prestreched . so you dont need much draw...
I shot with it comercial arrows for crossbow very fast, marbels , and steel balls .
#18 JoergS
JoergS
    2000 Post Club
  • Registered
  • 2,100 posts
Posted 12 June 2011 - 08:21 PM
Black7, that is pretty much the idea.
I started the work on this new weapon, and have finished the lock and trigger part pretty much.
The starting point:
Turned the nut in the lathe, from beech:
Fitted it in the tiller. The hole is for resting the ball in place. I know now you will say "magnet", but I want to shoot lead from it, too.
Here is the trigger part, to be operated with the looong lever
Secured the nut with a side plate. The nut can take a lot of force.
Will have to attach the prod (fork) and then take care of the "beauty" part - should be shooting tonite.
EDIT: Charles, I did change the dimensions. Longer draw, more narrow prod. It won't be an exact replica. Functionality rules!
Still, the draw will be a lot shorter than on my other slingshot crossbows. It will be interesting to see how much the prestretching helps.
Edited by JoergS, 12 June 2011 - 08:28 PM.
#19 Lizard_King
Lizard_King
  • Registered
  • 20 posts
Posted 12 June 2011 - 08:27 PM
Looking good ..
will you make a Rail that holds the ammo on right derection ? I made it on my crossbow , it's imposible to shot balls without it ..
here is comercial crossbow shotting balls
video
Edited by Black7, 12 June 2011 - 08:37 PM.
#20 JoergS
JoergS
    2000 Post Club
  • Registered
  • 2,100 posts
Posted 12 June 2011 - 08:36 PM
No. Anything that touches the ammo in flight will reduce speed, potentially harm the rubber and reduce accuracy. The "fork" will be two inches high, so the ball will be lifted up in order to fly straight.
Medieval stone crossbows followed the same principle.
I will use a pouch just like on a normal slingshot. The rails are needed only when you use string. As I don't plan to shoot arrows, I don't need the string.
Edited by JoergS, 12 June 2011 - 09:04 PM.
