Close
--Click to Remove Ads--
* * * * * 3 votes
Slingshot Forum 300 Club
  • Please log in to reply
21 replies to this topic
#1 Henry the Hermit
Henry the Hermit
    Geezer Gang
  • Moderators Moderators
  • 4,564 posts
  • LocationGeneva, Texas / Panama
Posted 28 January 2013 - 11:11 AM
Who is the fastest? Who has the most powerful slingshot? This is the place to find out. This first post will be where club members and their records will be kept. The rules and a sample video are included in each sub-Topic.
Power Rangers
Tobse - 80 lb/ft/109.5 joules 188 fps (1.0inch/25mm steel - 1024gr/67gm)
BC-Slinger 62.38 lb/ft 84.57 joules 201.6 fps (steel ball - 691gr/44.8gm)
Can-Opener 52.34 fpe = 70.96 joules 356.9 fps (.50 cal lead ball - 12 gram = 185 grains)
Charles 43.42 lb/ft 58.87 joules 189.4 fps (.75cal/19mm lead - 545gr/35.315gm)
Beanflip 43.02 lb/ft 58.33 joules 186.4 fps (.81cal/20.6mm steel - 557gr/36.1gm)
Tendele 31.56 fpe 42.79 joules 232 fps (15 mm lead ball - 264 grains)
Ash 27.76 fpe 37.64 joules 250 fps (.5cal/12.7mm lead - 200 gr/13 gm)
Creakyboy 27.42 fpe 37.17 joules (14-16 mm lead - 362.66 gr = 23.5 gm)
Henry in Panama 26.89 lb/ft 36.45 joules 198.7 fps (7/8 oz bank sinker, measured weight 306.6 grains/12.25 grams)
OldSpookASA 26.22 lb/ft 35.56 joules 254 fps (.495 lead - 182 gr/11.8 gm)
ShockleysWW4Slingbows 25.66 fpe = 34.79 joules 232 fps (steel ball 13.91 gm = 214.66 gr)
busySteve 25.04 ft lbs  33.95 joules 211.1 fps (5/8 inch steel ball - 253 gr = 16.4 gm)
Rayshot 24.95 ft lbs = 33.83 joules 198.9 fps (.575 lead ball - 184 gr = 11.923 gm)
M_J 24.4 lb/ft 33.06 joules 208 fps (.625cal/15.9mm steel - 254gr/16.44gm)
popedandy 23.73 lb/ft 32.2 joules 182.8 fps (.50cal/12.7mm leadbullet - 320 gr/20.73 gm)
Timdx 23.35 lb/ft 31.66 joules 301.8 fps (.44cal/11mm lead - 115gr/7.5gm)
Bullseyeben 22.2 lb/ft 30.16 joules 266.8 (.454cal/11.5mm lead - 140 gr/9.1 gm)
Bill Hays 21.1 lb/ft 28.6 joules 419.5 fps (.33cal/8.4mm lead - 54 gr/3.5 gm)
Speed Freaks
500 Level Members
Beanflip 519.6 fps (.25cal/6.35mm steel - 16 gr/1.05 gm - 9.7 lb/ft 13.15 joules)
Can-Opener 512,9 fps  (.25cal/6.35mm steel - 16 gr/1.05 gm - 9.35 lb/ft 12.67 joules)
BC-Slinger 512.7 fps (.25cal/6.35mm steel - 16 gr/1.05 gm - 9.34 lb/ft 12.66 joules)
Creakyboy 504.1 fps (6 mm steel - .89 gm = 13.735 gr - 7.75 fpe = 10.51 joules)
400 Level Members
TobseB 470 fps (.25cal/6.35mm steel - 16 gr/1.05 gm - 7.97 lb/ft 10.8 joules)
Luxor5 443 fps (.24 cal/6mm steel - 14gr/.95 gm - 6.26 lb/ft  8.49 joules)
Torsten 439.3 fps (.28cal/7mm steel - 23 gr/1.48gm - 9.28 lb/ft 13.26 joules)
Henry in Panama 432.5 fps (.25cal/6.35mm steel - 16 gr/1.05 gm - 6.75 lb/ft 9.15 joules)
Tendele 427 fps (6.35 mm steel -16 gr - 6.48 ft. lb. 8.78 joules)
bullseyeben 426.1 (.25 cal/6.35mm steel -16 gr/1.05gm - 6.55 lb/ft 8.88 joules)
Bill Hays 419.5 fps (.33cal/8.4 mm lead - 54 gr/3.5 gm - 21.1 lb/ft 28.6 joules)
OldSpookASA 413.1 fps (.25 cal/6.35 mm steel - 16 gr/1.05gm - 6.15 lb/ft 8.35 joules)
Charles 411.8 fps (.25cal/6.35mm steel - 16 gr/1.05 gm - 6.12 lb/ft 8.29 joules)
Flatband 402.1 fps (.31cal/7.9mm steel - 32 gr/2.06 gm - 11.39 lb/ft 15.44 joules)
300 Level Members:
MissLace  378.1 fps (.25cal/6.35mm steel - 16 gr/1.05 gm - 5.16 lb/ft 6.99 joules)
Quarterinmynose 356.3 fps (.25cal/6.35mm steel - 16 gr/1.05 gm - 4.58 lb/ft 6.21 joules)
The Pocket Shot 349.3 fps (.25cal/6.35mm steel - 16 gr/1.05 gm - 4.34 lb/ft 5.88 joules)
Lightgeoduck 338.7 fps (Plastic ball - 16 gr/1 gm - 4.14 lb/ft 5.6 joules)
Ash 327 fps (8 mm steel - 33.18gr/2.15gm - 7.88 lb/ft 10.16 joules)
Chico 326 fps (.375cal/9.5mm steel - 55 gr/3.55 gm - 12.94 lb/ft 17.54 joules)
gk1 304.3 fps (.25 cal/6.35mm steel - 16 gr/1.05 gm - 3.29 fpe 4.463 joules)
Calinb 303.8 fps (.25 cal/6.35mm steel -16 gr/1.05 gm - 3.28 fpe 4.45 joules)
Timdx 301.8 fps (.44cal/11mm lead - 115gr/7.5gm - 23.35 lb/ft 31.66 joules)
Edited by Charles, 26 May 2016 - 11:10 AM.
#2 NightKnight
NightKnight
    SSF Founder
  • Administrators Admin
  • 5,077 posts
  • LocationCentral Florida, USA
Posted 30 January 2013 - 09:44 AM
I like the changes!
#3 Guest_OldSpookASA_*
Guest_OldSpookASA_*
  • Guests
Posted 03 February 2013 - 06:57 PM
Well done, Henry!
#4 chico
chico
  • Resigned
  • 100 posts
  • Locationno longer here
Posted 04 March 2013 - 12:36 AM
im trying to figure out how you put the video on the page
Edited by chico, 04 March 2013 - 12:40 AM.
#5 Henry the Hermit
Henry the Hermit
    Geezer Gang
  • 4,564 posts
Posted 04 March 2013 - 05:33 PM
The easy way is to upload it to YouTube and link from there. If you become a Supporting Member ($12.00 per year) you can upload to your gallery.
#6 Tentacle Toast
Tentacle Toast
  • Banned
  • 10,020 posts
  • Location.
Posted 04 March 2013 - 06:44 PM
I'd love to check out Beanflip's 500fps rig; would someone be so kind as to direct me to pics please?
#7 BC-Slinger
BC-Slinger
    The King of Kings ...There is only 1...
  • Registered
  • 1,687 posts
  • LocationVictoria BC
Posted 04 March 2013 - 07:32 PM
Read through the actual speed freaks thred everyone that is in the club has there video posted there. To validate them being in the club.
#8 ruthiexxxx
ruthiexxxx
    2000 Post Club
  • Gold Sponsor Gold Sponsor
  • 2,064 posts
  • LocationAndalucia
Posted 31 July 2013 - 08:03 AM
For the Power Rangers it would be fascinating to know the details of how each of these terrific shots was achieved in terms of the type and size of band/tube used and the draw length. Does the info exist anywhere already ?
#9 libel
libel
    100 Post Club
  • Newbie
  • 106 posts
  • LocationMD
Posted 31 July 2013 - 08:57 AM
The headings are links to the topics :)
#10 ruthiexxxx
ruthiexxxx
    2000 Post Club
  • 2,064 posts
  • LocationAndalucia
Posted 31 July 2013 - 09:14 AM
ah...thank you :)
#11 Henry the Hermit
Henry the Hermit
    Geezer Gang
  • 4,564 posts
Posted 31 July 2013 - 09:13 PM
Power Rangers members must submit a video and list their equipment. It is all in the Power Rangers Topic.
#12 The Pocket Shot
The Pocket Shot
    100 Post Club
  • Registered
  • 152 posts
  • LocationGeorgia
Posted 30 September 2014 - 07:07 PM
Am I allowed to enter this competition?  I know the Pocket Shot is not exactly a "slingshot" but pound for pound I'd like to go toe to toe with somebody elses best most powerful version and see how it holds up.
Anyone got a tiny slingshot 2.3 inches or smaller that is super powerful please send me a video or link.
thanks
(maybe I should start a new thread for this)
#13 Charles
Charles
    4000+ Post Club
  • 10,756 posts
  • LocationBritish Columbia
Posted 30 September 2014 - 08:08 PM
thanks
All you need is a chronograph and a video camera. The size of the frame does not really matter.
Cheers .... Charles
#14 The Pocket Shot
The Pocket Shot
    100 Post Club
  • Registered
  • 152 posts
  • LocationGeorgia
Posted 09 October 2014 - 09:39 AM
My post is in the videos section.  I would upload it here but I don't know what the rules are for the forum.
#15 Henry the Hermit
Henry the Hermit
    Geezer Gang
  • 4,564 posts
Posted 09 October 2014 - 10:32 AM
If you're going for speed, load it to Speed Freaks. For power entries use Power Rangers. See the first post in this thread.
#16 leadball
leadball
    250 Post Club
  • Newbie
  • 288 posts
  • LocationNorth Carolina
Posted 14 October 2014 - 07:02 PM
I'm wondering what bands would give a man 300+ fps with say 32cal lead. With 3/4 butterfly or less. :stupidcomp:
#17 stinger
stinger
    750 Post Club
  • Newbie
  • 785 posts
  • LocationColorado
Posted 14 October 2014 - 08:22 PM
Holy POWER and SPEED. Well done gang. Zoooom. SPLAT!
#18 Charles
Charles
    4000+ Post Club
  • 10,756 posts
Posted 14 October 2014 - 11:03 PM
Well, you can begin by looking to see what others have used ... here for example:
http://slingshotforu...s-ssf-300-club/
Of course there is no single answer to your question. The only "band calculator" I know of is here:
http://www.slingshot.../band_calc.html
But it does not really specify speed, and it is only for Theraband Gold.
Cheers .... Charles
Edited by Charles, 14 October 2014 - 11:04 PM.
#19 leadball
leadball
    250 Post Club
  • Newbie
  • 288 posts
Posted 15 October 2014 - 06:07 AM
Thanks Charles
I seen the calculation chart once before, and have been looking for the chrony Connect app for some time.
#20 mbortolot
mbortolot
  • Newbie
  • 18 posts
  • LocationConnecticut
Posted 25 November 2014 - 07:17 AM
Can Anyone Find Timdx's Setup and share the link?
