Close
--Click to Remove Ads--
* * * * * 4 votes
Power Rangers
  • Please log in to reply
309 replies to this topic
#1 Henry the Hermit
Henry the Hermit
    Geezer Gang
  • Moderators Moderators
  • 4,554 posts
  • LocationGeneva, Texas / Panama
Posted 28 January 2013 - 11:00 AM
Do you enjoy shooting heavy pull slingshots with lots of power? Like to bust things up? This is the Club for you.
Here's how to become a Power Ranger.
  • Find a bandset/ammo combination that will produce at least 180 feet (54.86 meters) per second or higher velocity and 15 lb/ft (20.4 joules)
  • Make a video similar to the one in the next post.
  • You and the Chrony should be visible when the shots are made. After each shot, either zoom to the Chrony readout or move the camera close enough to see the readout, keeping the Chrony in view at all times. The most powerful shot must be backed up by at least one other shot within 5% of the same power. Please do not edit the video at any point between the first and last shot. It's OK to shoot a lot of shots and remove from each end, but the qualifying shots should be continuous.
  • Post the video and full information about the fork, bandset, and ammo. The same information about the ammo as above must be included. Include the dimensions, width, taper, relaxed length (fork to pouch tie), and pouch. Give the size and type of round ball. If you use any ammo other than round ball steel or lead, you must weigh the ammo. Use scales with an accuracy of .01% or better. Also state your approximate draw length.
  • The frame may be any form, but rubber must be drawn with one hand only. There are no restrictions on ammo weight.
The Android app "Chrono Connect" has been approved for both Speed Freaks and Power Rangers. To qualify for either Speed Freaks or Power Rangers with this app, please review and follow this tutorial.
http://slingshotforu...setup-tutorial/
The video must show your setup, including measurements from 1st sound producer to target. The 1st sound producer should be far enough from the slingshot that the pouch does not strike the sound producer. The distance from 1st sound producer to target must be entered into Chrono Connect precisely as measured and that distance must be at least 192 inches. Sound sensitivity of the app should be set to the lowest setting which will produce results. It is very important to follow the tutorial and these instructions exactly, as any deviation can result in erratic readings. Setups which do not conform to the tutorial will not be considered for qualification.
Edited by Henry in Panama, 01 April 2013 - 11:34 AM.
#2 NightKnight
NightKnight
    SSF Founder
  • Administrators Admin
  • 5,075 posts
  • LocationCentral Florida, USA
Posted 30 January 2013 - 09:43 AM
How long do you think it will be before we will break 100 ft/lbs?
#3 Henry the Hermit
Henry the Hermit
    Geezer Gang
  • 4,554 posts
Posted 30 January 2013 - 12:35 PM
I'm adding my instructional video and first entry for Power Rangers here to keep it as close to the top as possible. Please excuse the sniffing. I have some allergies working on me right now.
Frame: - Cashew Fork Ringshooter
Bands/tubes - looped Dankung 2040 tubes, 7 inches pull. Jim Harris (Performance Catapults) pouch
Ammo - .495 cal lead ball, measured weight 172 grains/11.2 grams
FPE - 16.8 lb/ft 22.78 joules
Velocity - 209.5 fps
http://www.youtube.com/watch?v=NOPPDFIO6fE&feature=youtu.be
Edited by Henry in Panama, 30 January 2013 - 03:28 PM.
#4 Charles
Charles
    4000+ Post Club
  • 10,749 posts
  • LocationBritish Columbia
Posted 30 January 2013 - 01:56 PM
I just used my CombowSling to fire .50 lead ball, weighing 170 grains, at 210.4 fps. By my calculations, that comes in at 16.7 fpe. Whew! Looks like I get to play with the big boys. Video is loading onto Youtube ... will post the link as soon as Youtube says it is ready.
Now, where are those stinking badges????? :headbang:
Cheers ...... Charles
#5 Henry the Hermit
Henry the Hermit
    Geezer Gang
  • 4,554 posts
Posted 30 January 2013 - 02:45 PM
Yep, we're gonna need some badges. I am also uploading a video. Would you believe 16.8 lb/ft with 2040 tubes?
Edited by Henry in Panama, 30 January 2013 - 03:38 PM.
  • M.J likes this
#6 Charles
Charles
    4000+ Post Club
  • 10,749 posts
Posted 30 January 2013 - 03:44 PM
All right, here is my video:
CombowSling
band length:  9.5 inches
slack length:  maybe 1 inch at most
band material:  some sort of latex tube ... came on this wonderful device
pouch: heavy, but flexible cow hide, 3 1/4 x 7/8 inches
my draw length with this setup:  42-43 inches
ammo: about .50 caliber lead ball, weighed on my digital scale at 170+ grains (cast with buckshot mold)
maximum velocity:  210.4 fps
measured velocities:  210.4, 206.5, 201.6, 203.1  all within 5% of each other
energy by my calculation:  16.7 fpe
Cheers ....... Charles
#7 Nicholson
Nicholson
    750 Post Club
  • Registered
  • 899 posts
  • LocationEAGLE RIVER, ALASKA
Posted 30 January 2013 - 04:50 PM
Congratulations Charles and Henry! This is going to be an exciting topic to follow :nerd:
#8 Henry the Hermit
Henry the Hermit
    Geezer Gang
  • 4,554 posts
Posted 30 January 2013 - 05:21 PM
I figure some of the younger, stronger guys are going to be showing us Old Geezers 50+ lb/ft in short order. Tobias has already shown us 80 lb/ft (100+ joules) and it won't be a big deal for him to repeat it. I see some exciting times ahead.
I want to caution everyone about the dangers at high power levels. A pocket pistol shooting .25 ACP generates about 65 lb/ft of muzzle energy. I think everyone will agree that a .25 ACP pistol is capable of killing, so if you are strong enough to pull a slingshot that can generate 50+ lb/ft, treat it with the same respect you would a handgun. Protect your fork holding hand and make sure your backstop will not cause ricochets. And get some good shooting glasses.
Edited by Henry in Panama, 30 January 2013 - 05:31 PM.
#9 Charles
Charles
    4000+ Post Club
  • 10,749 posts
Posted 30 January 2013 - 06:26 PM
Hey Henry,
Yep on the comment about the younger crowd. I figured I had better get my oar into the water before the young turks completely swamp us!
And right on about the caution. Catching a .50 lead ball moving at over 200 fps is guaranteed to make you feel worse than uncomfortable ...
Cheers ..... Charles
#10 bullseyeben!
bullseyeben!
    2000 Post Club
  • Newbie
  • 2,336 posts
  • LocationAdelaide, sth aus
Posted 30 January 2013 - 07:11 PM
Nice job guys! Charles, there's a chance you may have been shooting faster than you think, I noticed you shot through the chrony in a downwards direction, that creates a longer journey in between sensors for the ball.. just a guess but 220 may possible with a flat shot..?! Cheers
#11 Charles
Charles
    4000+ Post Club
  • 10,749 posts
Posted 30 January 2013 - 07:45 PM
Thanks, Ben. I probably was shooting a bit downward. I was still hitting my backstop up near the top. I tried to compensate by taking a really wide stance, but that was only partially successful. I was too lazy to get out a card table to raise my backstop up. I have some hopes of trying for a higher energy at a later date. But for now, I was just thankful to clear that first hurdle.
Now me lad, you have already done some outrageous performances. Time for you to give us all something to shoot for. Your temperatures down under ought to be conducive to some really high velocities this time of year.
#12 bullseyeben!
bullseyeben!
    2000 Post Club
  • Newbie
  • 2,336 posts
Posted 30 January 2013 - 08:02 PM
Either way Charles good results :)
Don't worry ill be putting in a few shots soon, unfortunately I'm all out of tb gold, so ill have to see what I can do with a heavy silver cut.. then again I do have some tubes just sitting there.. ( what? Me using tubes... that's un heared of lol)
Actually the weather has been quite mild lately, low mid 20c deg, so I won't have a great advantage there.. see how we go ;)
#13 M.J
M.J
    Six of one/ Half dozen of the other
  • 7,612 posts
  • LocationIndiana, USA
Posted 30 January 2013 - 08:32 PM
No kidding!
Nobody likes 2040s more than me but I can't even imagine using them with .495 lead. That shows the advantages of long draw and high temperature.
Fun stuff!
#14 Beanflip
Beanflip
    Bean it!
  • 3,806 posts
  • LocationKansas
Posted 30 January 2013 - 10:24 PM
I just had to break out my rusty algebra skills. With 44 cal lead (if all is correct) I would need at least 235 fps to be at or nearly 15 ft/lbs.           I had to look up the equation. Energy = Weight (in grains) times Velocity Squared divided by 450395 (fixed constant)  Then i had to find 44 cal weight in grains. 44 cal = .429 inch ? Used the ammo chart in downloads. approx 122 grains not quit 11 mm?  Any suggestions or corrections? Balls are from a do-it slingshot pellet mold.          Edit: mold info says 1/4 oz and that is only equal to 109 grains. Back to my rusty algebra.
Edited by Beanflip, 30 January 2013 - 10:28 PM.
#15 Beanflip
Beanflip
    Bean it!
  • 3,806 posts
  • LocationKansas
Posted 30 January 2013 - 10:34 PM
I need 248 fps with the 44cal do-it mold lead balls to reach 15 ft/lbs. Right?
#16 Henry the Hermit
Henry the Hermit
    Geezer Gang
  • 4,554 posts
Posted 30 January 2013 - 11:54 PM
The only way you can be certain of ball weight is to weigh them. Your alloy can vary weight by quite a bit. I have two Do-It molds and my current batch of .44 balls (actual diameter .429) cast mostly from wheel weights weigh 116 grains. To make it easy, here is an an Excel spreadsheet that will do the math for you. It gave me 242 fps with my balls for 15.09 lb/ft.
Attached File  AmmoCalc.xls   10KB   482 downloads
#17 Henry the Hermit
Henry the Hermit
    Geezer Gang
  • 4,554 posts
Posted 31 January 2013 - 12:02 AM
No kidding!
Fun stuff!
Indeed! On average I got about 5 fps faster speed with 1842, but that is more a reflection of my weakened condition after two pretty rough weeks of allergies and leg infection than the different potentials. I should be able to get about 10 fps more with 1842.
#18 bullseyeben!
bullseyeben!
    2000 Post Club
  • Newbie
  • 2,336 posts
Posted 31 January 2013 - 05:25 AM
Ok it was Daddy day care (evening shift) tonight, so didn't get much time to mess around, so I rigged up a pretty heavy tb silver band set to get an idea of how they lug the bigger balls.. Temp about 20c , shooting .454 lead balls.. I like the silver, and so far think .454 may be too small for this band rig !....? Cheers all..
#19 Beanflip
Beanflip
    Bean it!
  • 3,806 posts
  • LocationKansas
Posted 31 January 2013 - 07:24 AM
attachicon.gifAmmoCalc.xls
Do I need a special scale?
#20 NightKnight
NightKnight
    SSF Founder
  • 5,075 posts
Posted 31 January 2013 - 07:29 AM
Postal scales work well.
