Close
--Click to Remove Ads--
* * * * * 8 votes
Beginner Slingshot Builders Kit
  • Please log in to reply
73 replies to this topic
#1 Hrawk
Hrawk
  • Banned
  • 6,399 posts
Posted 28 October 2012 - 10:46 PM
POPULAR
We often get a lot of questions here from newcomers to the sport regarding what they need to get started. I thought I'd put together a quick post for all to see showing just how little an investment is really needed to start making your own quality shooters.
By no way will this be a definitive solution as people have created some awesome shooters with nothing but a small folding pocket knife but I hope some people will find this useful.
They way I see it, the most minimal amount of kit you would need for making board cuts and naturals is as follows:
  • Coping Saw
  • Rasp/s
  • Sandpaper
  • Finish (Optional)
-Coping Saw-
Coping saws are a great option for slingshot making. They are cheap. They can get into the tightest of curves and cut through the hardest of woods (with a bit of patience and elbow grease). The blade can be removed and inserted in a hole for cutting out shapes inside the frame. The blade can also be turned to face any direction for detailed work and ease of cutting. They are available just about anywhere for a small investment. They offer a large enough throat for the biggest of frames yet are capable of turning out even the smallest sized pocket shooter.
Coping Saw @ Harbour Freight $5.99
This particular one comes with a few different blades included, from rough cutting to extremely fine detailed work. I agree that a pruning saw or other hand saw would be better for cutting a natural fork from a tree, this particular saw is more than capable of doing the job.
-Rasp/s-
Similar in design to a metal file however the teeth are optimised for wood shaping and removal. There are literally hundreds of sizes, styles and tooth patterns available but don't confuse yourself with all the specifics. Your main concern right now is being able to shape the wood to your desired style. Rasps provide a very aggressive cutting action, getting your work done very quickly.
3 Piece Rasp Set @ Harbour Freight $2.99
This great set of rasps is ideal for putting final touches on your projects. The 3/4” flat rasp is designed for general purpose sanding and shaping on flat surfaces. The 7/8” half round rasp is built for flat, concave and convex surfaces. Finally, the 3/8” diameter round rasp is designed for shaving and forming tightly curved wood sections such as finger grooves, pinkie holes and even band grooves..
-Sandpaper-
I have heard it said time and time again that 90% of any form of woodwork is sanding and yup, it's pretty true. Having used the rasps to cut and mould your wood to shape, you will find the current surface of your project looks a bit ragged and for lack of a better word, crap. This where the sanding begins. Sandpaper is available in different grits, from very coarse to smooth as glass. The lower the grit number, the more aggressive it is at removing material. You will start with a lower grit and progressively move up to achieve the desired finish. After using the rasps you would probably go for a 40 or 80 grit paper, moving on to 120, 240, 360 and sometimes even higher. You will probably find that going to 220/240 is more than satisfactory for a good finish. If you want glassy smoothness, keep sanding :) You want to spend time and make sure that your fork tips are as smooth as possible as this will contribute to band life. Rough forks will wear your bands very quickly. Smooth is good.
Sandpaper is cheap. If you are starting out, grab yourself a couple of sheets of 80, 120 & 220 grit paper.
Sandpaper pack @ Harbour Freight $2.99
This assortment of sandpaper comes with a variety of grits. The assortment includes two sheets of 60 grit, three sheets of 100 grit, three sheets of 150 grit and two sheets of 220 grit aluminum oxide sanding sheets to help you accommodate a variety of jobs! This sandpaper assortment is a great set for any do-it-yourselfer or professional craftsman to smooth metal, finish wood pieces and sand paint away for a clear, clean surface.
-Finish-
Finishing, oh wow, where do I start. As I mentioned above this can be an optional step in the build however most people like to bring out the best in their choice of wood and give it that bit of extra bling. The options for finishing are endless and mostly come down to personal preference. Here I will list two options that are cheap and easy to do.
The first I will mention is Linseed oil, a personal favourite of mine. Like all the above tools, Linseed oil can be purchased just about anywhere. It is available as a raw or boiled product. Boiled is the preferred option of most as it has a considerably shorted curing (drying) time. Linseed oil can be purchased for only a few dollars. It can be wiped on with a rag/cloth, or your project can be soaked in it for a few hours to a few days. It does take time though, as curing times can be anywhere from a few days to a few weeks to achieve optimum results. It does however do an awesome job of bringing out the beautiful grain and colour in most woods. Linseed oil finish is usually further enhanced by a wax polish to bring out a nice lustre and shine. Expect to pay around $5 for a half litre bottle of boiled Linseed Oil.
Another option is aerosol based finishes. Once again you have a huge range of options here so I wont go into them all. Probably the most common of these finishes is spray on Polyurethane. Comes in a can just like spray paint and is very easy to apply. Usually you would hang your slingshot up and apply several THIN coats, emphasis on thin. It is very important to ensure that each coat has completely dried before applying the next. For best results it is also best to sand between coats for that super smooth glassy look. Common options here are to use 800 grit sandpaper or even steel wool. Whatever you do, don't try to do it all in one go as you will end up with a thick tacky coat and possibly drip marks. Multiple thin coats is the trick to a great finish. Myself I like to use a spray on marine varnish as this also offers great UV protection against fading. These products also offer the option of a satin, semi gloss or gloss finish. Expect to pay between $5 and $10 for a good spray on finish. One can is usually enough for 2 to 5 frames, depending on number of coats you use.
Well there you have it. Ignoring the finish for the moment, for an initial outlay of approximately $12 dollars, you are well on your way to building your very own slingshot.
Check out the Templates tab at the top of this forum for some great designs to get you started. Just print them out, glue them to your wood and get started !
If you have found this post helpful, please click the 'Like This' button in the lower right hand side of this post :)
Edited by Hrawk, 28 October 2012 - 10:47 PM.
#2 Hrawk
Hrawk
  • Banned
  • 6,399 posts
Posted 28 October 2012 - 10:48 PM
This thread was created as a very basic guide for the beginner builder.
If you have something that you think needs to be added to this, please let me know and I will edit in your input.
#3 bullseyeben!
bullseyeben!
    2000 Post Club
  • Newbie
  • 2,336 posts
  • LocationAdelaide, sth aus
Posted 29 October 2012 - 12:57 AM
Good advise mate, apart from a dremmel, my main tool for making a frame, ... a hole saw is also a cheap, yet good investment that speeds up a round cut inside fork cut, and with many diff sizes available can be used to pre shape the waist and handle grip too.. good post mate..
#4 Hrawk
Hrawk
  • Banned
  • 6,399 posts
Posted 29 October 2012 - 01:16 AM
Thanks Ben :)
I've answered these questions so many times in chat and in other places, I figured my life would be easier if I just had a thread I could refer people to.
Hole saws are awesome, that's how I do most of my fork gaps on board cuts.
#5 popedandy
popedandy
    100 Post Club
  • Newbie
  • 249 posts
  • LocationMaryland
Posted 29 October 2012 - 05:08 AM
Thanks, Hrawk. It is amazing to see how little it takes and how little it costs to get started.
#6 Sofreto
Sofreto
    1000 Post Club
  • 1,186 posts
  • LocationPeople's Republic of California
Posted 29 October 2012 - 06:43 AM
Great summary...well done.
#7 Blue Danube
Blue Danube
    Sometime Craftsman/ Artist of the Chalice
  • Registered
  • 713 posts
  • LocationUSA
Posted 29 October 2012 - 07:39 AM
Blocks n wood dowels for contour sanding? Great job covering basics other wise
#8 M.J
M.J
    Six of one/ Half dozen of the other
  • Moderators Moderators
  • 7,611 posts
  • LocationIndiana, USA
Posted 29 October 2012 - 08:15 AM
Good advice on how to make a frame, but it's not really a slingshot until it has bands :)
#9 Jim Williams
Jim Williams
    Craftsman
  • Gold Sponsor Gold Sponsor
  • 1,358 posts
  • LocationSheffield UK
Posted 29 October 2012 - 09:33 AM
Great post Hrawk!
#10 f00by
f00by
    Slingtastic
  • Registered
  • 1,205 posts
  • LocationSan Francisco
Posted 29 October 2012 - 02:01 PM
Good idea!
#11 Sean
Sean
    2000 Post Club
  • 2,374 posts
  • LocationB.C Canada
Posted 29 October 2012 - 05:42 PM
Good job Hrawk, glad you pinned it.
#12 inkspot
inkspot
    100 Post Club
  • Newbie
  • 220 posts
  • LocationWhitby On.Canada
Posted 29 October 2012 - 06:31 PM
Thanks Hrawk this is a great post.
#13 Knoll
Knoll
    1000 Post Club
  • 1,002 posts
  • LocationW of St Louis
Posted 30 October 2012 - 09:10 AM
Good post, bud. That's much what ya advised me a year ago.
#14 wood'n'rubber
wood'n'rubber
    100 Post Club
  • Newbie
  • 181 posts
  • LocationIndia
Posted 31 October 2012 - 07:50 AM
Nailed it! Thanks Hrawk!
#15 NightKnight
NightKnight
    SSF Founder
  • Administrators Admin
  • 5,070 posts
  • LocationCentral Florida, USA
Posted 31 October 2012 - 08:02 AM
You should really hit the "Blog This" button on that top post. Just a suggestion. :)
#16 f00by
f00by
    Slingtastic
  • Registered
  • 1,205 posts
Posted 03 November 2012 - 12:23 PM
Should this be in DIY section? Just wondering since the whole splitting of the section camp up from Aaron...?
#17 CK Slingshots
CK Slingshots
    100 Post Club
  • Newbie
  • 106 posts
  • LocationUSA
Posted 03 November 2012 - 12:42 PM
Just I used when I started!
#18 drfrancov
drfrancov
    100 Post Club
  • Newbie
  • 209 posts
  • LocationIronwood, MI, USA
Posted 03 November 2012 - 07:29 PM
POPULAR
And here is a video of the whole process using most of the tools above:
#19 drfrancov
drfrancov
    100 Post Club
  • Newbie
  • 209 posts
Posted 03 November 2012 - 07:37 PM
A few good videos for begginers that deal with bands:
#20 porcelanowy
porcelanowy
    100 Post Club
  • Registered
  • 134 posts
  • LocationPoland
Posted 05 November 2012 - 08:53 AM
Hello
For all boardcutting beginners I would add your inkscape tutorials :)
Aaaand thank you... again ;)
