Daisy B52 mod: help request
mod daisy
  • Please log in to reply
17 replies to this topic
#1 Abe_Stranger
Abe_Stranger
  • Members
  • 210 posts
  • LocationColorado
Posted 06 February 2012 - 07:44 PM
Hello, All:
I have just removes the wrist-support from my B52, and it shoots much better. The only problem is that the squarish shap kind of digs into my hand when I draw. I thought of using electrical tape to soften up the shape, but I'm sure someone out there has a better idea. Any suggestions?
#2 Henry in Panama
Henry in Panama
    1000 Club
  • Moderators
  • 1,266 posts
  • LocationPanama
Posted 06 February 2012 - 07:52 PM
View PostAbe_Stranger, on 06 February 2012 - 07:44 PM, said:
Hello, All:
Unfortunately, the B-52 does not lend itself to easy handle modification. Unlike the F16 it does not have a full length steel section handle. The steel portion extends only a bit more than half way into the plastic handle, so any handle change must be very strong and solid. IMO you would be much be better off to shelve the B-52 and replace it with something better. I no longer shoot my B-52.
#3 Imperial
Imperial
    SLINGSHOT GUERRILLA
  • Members
  • 1,110 posts
  • LocationHELLPERIAL, MEXIFORNIA
Posted 06 February 2012 - 09:15 PM
maybe a sleeve of sorts over it ? styrofoam comes to mind, the water noodles ( think thats what they are called ) or something of the sort . or take off the handle and add a handle to it . fimo clay comes to mind and maybe some of that solid epoxy stuff . or just use it without the handle as a small shooter . someone on here took off the handle and wrapped lanyard around it as used it as a small hand sized mini shooter .
#4 mattardel
mattardel
  • Members
  • 158 posts
  • LocationCalifornia
Posted 06 February 2012 - 11:16 PM
I would suggest taking off the outer plastic casing completely, and wrapping it in paracord.
Attached File  DSC02572.JPG   182.73K   4 downloads
I know this isn't the same one (it's actually a Crosman Firestorm), but it has a similar shape. Fits a lot better in the hand and you can change the thickness by adding layers of cord.
#5 Abe_Stranger
Abe_Stranger
  • Members
  • 210 posts
  • LocationColorado
Posted 06 February 2012 - 11:27 PM
Hello, All:
Henry has a point, and a kick-a** hat, but the latter is beside the point. The B52 fork structure only extends about a third, or less, of the way down the handle. The main reason I want to continue using the B52 is because my wife gave it to me for Christmas, and it has sentimental value to me; if this weren't the case, I'd toss it under a truck. I'd love to try the paracord grip mattardel, but it isn't feasible due to the short fork foundation. Cool design, though. I'll have to try that when I have the oppurtunity. As for the foam padding, Imperial, I like the idea. I'll have to look for thin foam sheeting next time I go to the hardware store.
I'm out of words for now, fellas; have fun/
Until next time,
Stranger
#6 adeptus_minor
adeptus_minor
  • Members
  • 44 posts
  • LocationTexas
Posted 07 February 2012 - 01:30 AM
Could you maybe do a carved wooden handle into which you would fit the fork assembly and then fasten it with epoxy?
(just a guess... I haven't seen what the forks look like with the plastic off)
Edited by adeptus_minor, 07 February 2012 - 01:36 AM.
#7 Jesus Freak
Jesus Freak
    Jesus Saves!
  • Members
  • 1,103 posts
  • Locationnorth carolina
Posted 07 February 2012 - 05:31 AM
That one looks really great!
#8 Henry in Panama
Henry in Panama
    1000 Club
  • Moderators
  • 1,266 posts
  • LocationPanama
Posted 07 February 2012 - 08:49 AM
This is the problem, guys. The B-52 frame is just not designed for easy handle mods. Here's a pic of my disassembled B-52.
Attached File  b-52-disassembled.jpg   49.75K   3 downloads
#9 Charles
Charles
    2000 Club
  • Moderators
  • 2,716 posts
  • LocationBritish Columbia
Posted 07 February 2012 - 10:34 AM
I think fitting a new wooden handle is the obvious way to go. Just cut a couple of blocks a bit bigger than those plastic ones, inlet grooves for the frame, and screw/glue the blocks in place. Then shape the blocks to suit. That would be at least as strong as the plastic grips that came on it.
Cheers ...... Charles
#10 Henry in Panama
Henry in Panama
    1000 Club
  • Moderators
  • 1,266 posts
  • LocationPanama
Posted 07 February 2012 - 10:46 AM
Probably stronger, Charles. One reason I stopped shooting mine is that I can feel the handle flexing with strong tubes.
#11 Deltaboy1984
Deltaboy1984
  • Members
  • 102 posts
  • LocationDFW Texas
Posted 11 February 2012 - 03:01 PM
Good Idea the wood will do the trick.
#12 Abe_Stranger
Abe_Stranger
  • Members
  • 210 posts
  • LocationColorado
Posted 11 February 2012 - 10:04 PM
Hey, guys. I've been at it again, and I think I have something suitable. What do you think? It needs some work, and I have a second piece--the second piece some kind of cedar, AFIK--ready to go after testing this. I think it's pine; the dowels were simply marked "DOWELS," with no wood ID on them.
WB grip, 3
Uploaded 08 Feb 2012 - 23:41
WB grip, 2
WB grip, 1
Uploaded 08 Feb 2012 - 23:40
#13 Charles
Charles
    2000 Club
  • Moderators
  • 2,716 posts
Posted 11 February 2012 - 10:22 PM
Waiting to see what you think of it after it is fitted ... You will be the ultimate judge of its suitability.
#14 AZ shooter
AZ shooter
  • Members
  • 193 posts
  • LocationArizona
Posted 11 February 2012 - 11:04 PM
You might try inserting the short handle into some sort of tubing...Metal, fiberglass, pvc, and filling it with epoxy...or possibly shaping a micarta handle around the short wire frame
#15 Sharkman
Sharkman
  • Members
  • 209 posts
  • LocationMinnesota
Posted 12 February 2012 - 10:51 PM
I think Charles has the most workable solution. Should add stability that it lacks. To bad about the lack of stability too because I love the 550 cord solution.
#16 sniper62
sniper62
  • Members
  • 37 posts
  • LocationDallas,Ga
Posted 08 March 2012 - 10:52 AM
I put Trumark tapered bands on mine so the easy pull makes up for the short handle.
Second pic taken before I swapped bands
Edited by sniper62, 08 March 2012 - 10:56 AM.
#17 WTBJR
WTBJR
    250 Club
  • Bronze Sponsor
  • 480 posts
  • LocationWestern North Carolina
Posted 09 March 2012 - 04:48 AM
Very nice modification
#18 pop shot
pop shot
    i can shoot a soda can from two feet away.
  • Silver Sponsor
  • 1,108 posts
  • LocationKailua, HI, Land of the EWOK
Posted 09 March 2012 - 03:42 PM
here's how you fix it- send henry $13.00 and your address and get a badass, durable aluminum bentwire.
