Shooting Flats with Wire Frame Slingshots.
  • Please log in to reply
7 replies to this topic
#1 Henry in Panama
Henry in Panama
    1000 Club
  • Moderators
  • 1,261 posts
  • LocationPanama
Posted 05 November 2011 - 02:46 PM
Recently I made some 1/4 inch aluminum bent-rod frames for AJW and a couple extra to experiment with. While the 1/4 inch rod is easier to bend than 5/16, if you plan to try it, you should know that my pattern will not be strong enough to avoid unwanted bending unless you wrap it, or insert a wooden handle, or build up a handle with Fimo.
The first one I made from 1/4 inch rod has a Fimo handle and extra long TB Yellow tubes, so I decided to try flats on the other one. First I wrapped the handle with Desert Camo Paracord, then worked a length of TB Red over each fork and tied off the ends. This step is not really necessary, but I'm hoping it will increase band life. Then because I had seen others do it, I reversed the fork so the ends were pointing forward and tied on a 107 bandset. Here's what that looked like.
Attached File  br-flats.jpg   729.37K   105 downloads
It only took a few rounds of 3/8 (9.5mm) lead to realize that this configuration is a champion hand-slapper. When it was still painful with .429 (11 mm) lead, I turned the fork back to normal, retied, and voila!, the handslap was gone even with 1/4 (6.4mm) steel, though that ammo did produce some stiff recoil which was not present with 3/8 lead. Here's a couple of pics of the finished product.
Attached File  br-flats-2.jpg   746.76K   106 downloads Attached File  br-flats-3.jpg   695.59K   72 downloads
The 107s are cut for a 7 inch length from tie to pouch and are secured to the frame with Alliance Sterling #64 rubber bands. They are tied as side shooters to eliminate twist.
This is a good shooter and I anticipate good band life.
#2 pop shot
pop shot
    i can shoot a soda can from two feet away.
  • Silver Sponsor
  • 1,101 posts
  • LocationKailua, HI, Land of the EWOK
Posted 05 November 2011 - 04:09 PM
That looks great with 107's!
#3 NaturalFork
NaturalFork
    Appreciate nature.
  • Bronze Sponsor
  • 4,192 posts
  • LocationNew Hampshire
Posted 05 November 2011 - 04:21 PM
Bent rods make awesome slingshots. I love them. Good work that one looks great!
#4 Blue Danube
Blue Danube
    250 Club
  • Members
  • 323 posts
  • LocationUSA
Posted 05 November 2011 - 05:42 PM
Henry, Well Done! Neat improv with the 107's.
#5 Charles
Charles
    2000 Club
  • Moderators
  • 2,710 posts
  • LocationBritish Columbia
Posted 05 November 2011 - 05:43 PM
That is a very nice looking slingshot. I should probably try bending one up ... after my 1000 other projects! :rofl:
Cheers ..... Charles
#6 Henry in Panama
Henry in Panama
    1000 Club
  • Moderators
  • 1,261 posts
  • LocationPanama
Posted 05 November 2011 - 05:58 PM
If anyone wants to give it a shot, here's a link to my short tutorial on how to make the frame.
http://oldpeddler.co...w-to/index.html
#7 Charles
Charles
    2000 Club
  • Moderators
  • 2,710 posts
Posted 05 November 2011 - 08:05 PM
Thanks for the link!
Cheers ...... Charles
#8 Vekta
Vekta
  • Members
  • 165 posts
  • LocationCA
Posted 15 November 2011 - 08:27 PM
Hey, wha'dew'ya know...I was thinking about this the other day!
Never thought of experimenting with fork tips reversed.
