Hello,
as you may know, I am currently asking my youtube subscribers what they want me to focus on.
Many people want to see slingshots that are powerful, but that have a low draw force so that average guys that aren't weightlifters can handle them.
The key, of course, is shooting smaller ammo. I have focused on the 9,5 mm steel balls (3/8 ") as those are common and cheap.
I started out with Thera Band Gold, cut 23cm x 2,8cm x 1,8 cm, a single band per side. Effective length from pouch to fork is about 20 cm.
That is a very light band with a very easy pull.
It does about 80 m/s, 262 fps.
Then, I changed the band size to 23cm x 4,1cm x 0,5cm - this is exactly the same amount of rubber. And the same pull! With eyes closed, you can't tell which band is on.
Also, I made a very small pouch, just large enough for the 3/8 " balls.
The results are astonishing. 96 m/s, 314 fps! With a band so light a preteen boy can probably pull out.
Next, I will use Thera Band Blue, cut it 23cm x 12,4cm x 1cm. This will have the same draw force as the Blue band is about 1/3rd of the thickness.
Let us see if I can propell the ball beyond 100 m/s!
This is fun.
