Right i have finished all shaping and cutting and put a epoxy glue finish on it but it still looks the same how do i put a shinny finish on the sling and darken. The wood but still being able to see the grain of the borad cut ahhh helppp
secret sata sling help
Started by
slingshotvibe
, Oct 18 2011 07:59 PM
6 replies to this topic
#1
Posted 18 October 2011 - 07:59 PM
#2
Posted 18 October 2011 - 08:14 PM
Sand it back with a 1000 or 1200 grit paper.
Then polish up with a bees wax or something similar.
#3
Posted 18 October 2011 - 08:19 PM
Thanks how much is bees wax and does it make it sticky
#4
Posted 18 October 2011 - 08:24 PM
Yes a good fine sand, I start with 180 grit and work up to usually 400 grit, but you can certainly go higher... i personally like a laquer or polyeurathene gloss coat...three to 4 coats with a spray pack...
#5
Posted 18 October 2011 - 08:27 PM
Ima sand it down tomoz then gunna get some clear laquare cheers bud
#6
Posted 19 October 2011 - 06:43 PM
Wet sanding will help save on abrasives. Epoxy will clog up your paper quickly, using water with a waterproof abrasive works really well and provides a better finish.
#7
Posted 19 October 2011 - 06:53 PM
All my acrylic stuff has to be sanded wet if I want more then 10 seconds from the paper.
