Close
--Click to Remove Ads--
* * * * * 4 votes
Alliance #107 Rubber Band Tests
  • Please log in to reply
309 replies to this topic
#1 Henry the Hermit
Henry the Hermit
    Geezer Gang
  • Moderators Moderators
  • 4,545 posts
  • LocationGeneva, Texas / Panama
Posted 13 August 2011 - 12:33 PM
POPULAR
One of my favorite flat bands are ordinary Alliance #107 rubber bands, available from most office supply stores in the US, though I buy mine from Amazon.com. They are cheap, require no tricky cutting and last a long time. Are they good enough for you? Good question, so I decided to do some tests to help you decide.
For comparison, I used two identical frames, my own design La Cholita in half inch plywood. One frame was banded with #107s and the other with .050 food grade latex from RubberSheetRoll.com cut the same width as the #107s. Both bandsets were fitted with Performance Catapult's (Jim Harris) pouches. I tied them on with thin strips of TB Gold in an OTT configuration and 8 inches between the pouch-tie point and the frame.
The first step was to fire 25 break-in rounds with each slingshot. I used .375 (9.4 mm) lead balls, and got a bit of hand-slap with both, indicating there is more energy available. Then I measured my draw-length at 34 inches, and using a digital fish scale measured the pull strength at 14.08 pounds for the #107s and 11.44 pounds for the latex.
Next I set up my speed test equipment, consisting of a metal chair with a wooden stick affixed to the back and a clothespin to hold a 5x8 inch index card located exactly 10 feet away from my catch box fabric. Then I placed my Acer Netbook on the chair and using Audacity, I recorded the sounds of a dozen or so shots from each slingshot hitting first the 5x8 card and then the cloth backstop 10 feet away. Then I transferred the files to my big computer and read the files to measure the elapsed time between the two strikes. I entered that information into a spreadsheet and calculated the speed in fps for each shot and finally got an average speed and energy. Here are the results.
#107
Average for 10 shots = 173.87 fps, 5.03 lbs/ft energy
.050 latex
Average for 10 shots = 183.95 fps, 5.60 lbs/ft energy
So far, no surprises. I expected the latex to be faster, but was pleasantly surprised to find the #107s to be as fast as they are.
Next, I will shoot both slingshots until the bandsets wear out or break. Past experience tells me to expect about 300 shots from the latex and more from the #107s. Every shot is recorded, so for the first time I will have an accurate count. Whichever breaks first will be replaced with a set of Tex's Field bands, and I will do the same speed, energy, and longevity tests on them, for comparison purposes. Note: Everyone already knows that Tex's bands are as good as it gets, so there really is no need for me to reinvent the wheel.
Henry
14 August, 2011 - The left side latex band broke at the pouch after 390 shots.
15 August, 2011 - 490 shots total on #107 bands. Very light scuffing at fork. No tears.
16 August, 2011 - 600 shots total on #107 bands. No tears.
17 August, 2011 - Velocity test - 178.7 fps 5.3 lb/ft energy
19 August, 2011 - Band broke at 696 shots
Edited by Henry in Panama, 28 October 2011 - 05:39 PM.
Update
#2 M.J
M.J
    Six of one/ Half dozen of the other
  • 7,611 posts
  • LocationIndiana, USA
Posted 13 August 2011 - 12:40 PM
Good info and testing methods, Henry!
I look forward to the longevity portion of the test.
#3 mckee
mckee
    2000 Post Club
  • Newbie
  • 2,958 posts
  • Locationbritain
Posted 13 August 2011 - 12:47 PM
man those are fast
#4 AZshooter
AZshooter
    250 Post Club
  • Registered
  • 366 posts
  • LocationArizona
Posted 13 August 2011 - 01:37 PM
Henry...which type of Alliance #107 were you using....Pale Crepe Gold. or Sterling...I imagine the Gold would be the best choice with higher rubber content....
#5 danielh
danielh
    100 Post Club
  • Newbie
  • 132 posts
  • Locationgeorgia
Posted 13 August 2011 - 02:21 PM
Maybe i missed it, how many rubber bands did you use, or was it just one whole band per side? this interest me alot for my BB shooting.
#6 Henry the Hermit
Henry the Hermit
    Geezer Gang
  • 4,545 posts
Posted 13 August 2011 - 02:32 PM
These are Sterling. Next time I'll try Gold Crepe.
Henry
#7 Henry the Hermit
Henry the Hermit
    Geezer Gang
  • 4,545 posts
Posted 13 August 2011 - 02:38 PM
I use one band per side and trim to length. These bands are much too heavy for BB shooting. I'm getting light band slap with .44 cal lead. I use some scrap TG Gold (Thanks Dan, ZDP-189) cut 1/2 inch x 1/4 inch by 9 inches for BBs. It's more than enough.
Henry
#8 philly
philly
  • 2,595 posts
  • LocationNorth East
Posted 13 August 2011 - 02:54 PM
Good thread Henry, I will be following it with intrest.
#9 AZshooter
AZshooter
    250 Post Club
  • Registered
  • 366 posts
  • LocationArizona
Posted 13 August 2011 - 03:12 PM
Rather than trim the band to length, you might try using the whole band with a loop at the fork end. This might add a tapered effect and add an extra thickness at a point where you tie to the forks. I was going to rubber cement this extra band area to eliminate friction between the two layers of rubber. I would probably try that type of rubber cement used for bicycle patch...maybe contact cement...not sure yet...Maybe others have tried this to eliminate friction between bands at critical contact points...(?)
#10 Charles
Charles
    4000+ Post Club
  • 10,713 posts
  • LocationBritish Columbia
Posted 13 August 2011 - 03:17 PM
Very, very useful stuff ... keep up the good work!
Cheers ...... Charles
#11 Henry the Hermit
Henry the Hermit
    Geezer Gang
  • 4,545 posts
Posted 13 August 2011 - 03:25 PM
Hey! You're getting ahead of me. LOL!
My friend AJW has a Flat Cat that is eating flatbands with gusto, I'm going to make him a set like that to try on it.
On my Panama Tipicos, I fold a portion of the band back and underneath to eliminate abrasion at the fork.
Henry
#12 Dayhiker
Dayhiker
  • 11,196 posts
  • LocationUSA
Posted 13 August 2011 - 03:32 PM
Good work, Henry. Good work. Thank you.
#13 AZshooter
AZshooter
    250 Post Club
  • Registered
  • 366 posts
  • LocationArizona
Posted 13 August 2011 - 03:43 PM
Thanks a lot for the useful information...much time and materials saved!
#14 philly
philly
  • 2,595 posts
Posted 13 August 2011 - 03:48 PM
Amazon has them for $7.49 for 1 lb box, 50 bands, shipping is $6.50, still a cheap alternative to 25 sets of purchased Latex bands.
#15 BaneofSmallGame
BaneofSmallGame
    Here to help and learn
  • 782 posts
  • LocationUpstate New York, USA
Posted 13 August 2011 - 06:46 PM
I love my Alliance Sterling 107's, they work wonderfully for target shooting ,especially for marbles. These days though I mainly use them as throw ins in my trades. In fact, Dayhiker has most of my stock at this point :lol:
But they certainly have there good uses. I also have some Universal 105s (total garbage with almost no latex!) :hmm: And the Alliance Gold Crepe, which I do not recommend, For some reason they just do not have any poke to them. I can't even get single bands to fire bb's with any speed!!! I have to say, the Sterlings are the way to go, if you want to use even heavier ammo you can use a cocktail set up as well, like DragonMaster does....
If you guys want some more info on these, there is some great info on this thread from long ago:
http://slingshotforu...__fromsearch__1
Great testing Henry, thanks
Cheers - John
Edited by BaneofSmallGame, 13 August 2011 - 06:46 PM.
#16 As8MaN
As8MaN
    250 Post Club
  • Newbie
  • 425 posts
  • LocationISR
Posted 13 August 2011 - 07:32 PM
Awesome bands, i wish that one day they will ship it to my country (Israel)... if so, i will buy like bunch of em!.
And thanks Henry :)
#17 TastelikeSnozberries
    100 Post Club
  • Newbie
  • 244 posts
  • Locationthereabouts
Posted 13 August 2011 - 08:14 PM
I've used sterling 107s cut in half (ie one complete loop cut into two strips to make one complete bandset) and even untapered they put a 5/16 hex nut clean through an empty soda can from 10 meters. They're plenty zippy
#18 Henry the Hermit
Henry the Hermit
    Geezer Gang
  • 4,545 posts
Posted 13 August 2011 - 08:22 PM
And thanks Henry :)
Since you have one of my Typical Panama Slingshots with 107 bands, can you tell us how they perform for you, and how long they lasted?
#19 NaturalFork
NaturalFork
  • 6,244 posts
  • LocationNew Hampshire
Posted 13 August 2011 - 09:02 PM
Do not use the gold crepe. They are very slow. Now I have to get more 107's as I have never tried the sterling
#20 M.J
M.J
  • 7,611 posts
Posted 13 August 2011 - 09:55 PM
Staples will ship them to one of it's stores for free. I paid like $7 total for mine.
  • Eli likes this
