1 votes
How does draw strength affect accuracy?
Posted by
ZDP-189
in
Technical
08 August 2010
performance bands flatbands accuracy
I've known for a while that the heavier I have to pull, the less accurate and consistent my shots are. I've been looking for ways to describe or quantify that, because I want to establish my optimum draw strength for accuracy. By using heavier bands and heavier ammo I should shoot flatter and straighter, but after a certain point, inaccuracy starts to creep in.
My current approach is to use a laser attached to the frame.
I cut a precise groove in the centre of the base, aligned perpendicular to the plane of the forks. Actually, this accuracy is not necessary for the test.
The groove accepts a sight rail which is screwed on. The laser sight is fixed to the rail.
It is shown with a pressure switch, but for the tests I used a second end cap that has a constant-on switch.
Note that this device is not for aiming or even for live firing. Slingshots are not aimed like that. It is the relative position of the fork and pouch hand that aims the shot, not the way the fork is pointing. Instead what this device does is reveal the degree to which the fork is wobbling.
Control: No Load
The control is my baseline. You can see it all stays in the 3" ring and moves slowly.
Fork Held in Two Hands
This simply illustrates that steadying the fork achieves less spread and slower movement.
7lbs Draw Weight
With a little weight, I can see more movement, but it's still under control.
11lbs Draw Weight
There is no significant degradation at 11 lbs.
14lbs Draw Weight
At 14 lbs, there is more significant wobble. I'd need heavier bands to test a stronger draw.
Some thoughts:
